the joys of dealership workmanship
801 11
I was rotating the tires yesterday and I found that one of the four bolts,which I think hold the hub onto the rear axle, seemed pretty loose. More than hand tight but not more than 15-20 lb ft tight. It seems a little on the low side to me. This was the same side that I had the axle seal replaced so I know why its loose. The other side was around 50 lb ft so I tightened it to that. But I was wondering if anyone knew how tight the bolts should be? Thanks.
1 - 12 of 12 Posts
....edited.... misread
Lug nut torque setting is 98 ft-lbs.
That's what I thought he was talking about at first to BB, but then I reread and it said FOUR bolts....
I think maybe he's referring to the retaining plate that is on the end of the axletube, which holds the bearing in place???
Part No. 3 in this illustration:
Good point, Warrior. I didn't catch that. Not sure about that torque spec.
Yep, that's what I'm talking about. The bolts, well nuts, that are threaded onto part 3's studs in the drawing are accessed from behind the brake rotor and seem to be what holds the bearing onto the axletube.
Do you know what size the bolts are?
That would be about a 3/4" head size.... So the shank would be about 12mm or around 1/2".
Torque for a Grade 8 would be around 60 ft-lb.
You should probably verify this with your Dealer's tech dept.
If it were me, I'd just use a 3/8" drive ratchet and tighten them till it feels right, because I always forget that I DO have a torque wrench!!
1 - 12 of 12 Posts
