1 - 2 of 2 Posts
I love my 2018 Titan SV but I really want to reduce body roll in the turns at higher speeds (freeway connecting ramps etc.). I use my 4x4 rarely and will most likely never be in a situation where reduced wheel articulation will be an issue. Has anyone here installed a thicker swaybar with positive results? I really don’t want to spend the money to change out the struts or go coil-over. Any advice?
I can't speak for the Gen2 trucks myself, but yes absolutely upgrading your sway bars definitely improves cornering stability!
I have the Helwig in the rear and it really keeps the rear end of my T planted flat on the road through the corners.
Lately though I've been thinking more about upgrading my front sway bar to the Belltech and PRG endlinks.
Right now on the front I only have the custom billet sway bar mounts with upgraded poly bushings that were made by an old TT Member named, Stilltime. 👍
1 - 2 of 2 Posts
