Currently have the 18" dual in/single out Magnaflow ( part #12258 ), and it's a little loud around 2500rpm. I have about 10-12" of room after the Magnaflow where I could add something that is 2.5" center in/center out...not much room to work with in front of the muffler since I have dual pipes into the magnaflow. I thought of adding a one-chamber (series 10) Flowmaster after the Magnaflow sort of as a resonator, and I figured it may add a slight rumble to the exhaust note as well. Since the one-chamber is the perfect length, it should be an easy install...but what do you think it would do to the sound?
