1 - 8 of 8 Posts
Hi.
I was wondering if there is fluid in those pipes that run through throttle body. If I take the piping off would it leak hard? Whats the right way to do this? I bought some silicone high temperature pipes and want to replace stock tommorow, as well as putting TBS (guess that would be the right time to do the bypass.)
Also, if I were to replace all stock pipes, should I drain the fluid first? How do I do this?
Yes....it pumps antifreeze through the TB.
I got a piece of conector tube...and ran the two rubber hoses together...and got a rubber cover for the two inlets on the throttle body.
pi3yeargrad said:
I didnt get ay fluid leakage through mine whe doing the TB Bypass...
Neither did I.
I did! Engine still a bit waqrm from a few hours earlier.
I did it with two valves, was not pleased with the curvature in the hoses. I'm going to change from a straight barb to a 90 Degree barb, one on each valve. This will make a shorter, direct fit that I can trust more.
Fairly easy install, even if no noticeable differance, might as well do it. :)
1 - 8 of 8 Posts
