I have a 2005 se 4x4 gas engine with 197k on it, it smokes on start-up, and sometimes even blows white smoke the entire time its on, that smoke smells like antifreeze, start-up smoke smells like burnt oil. Engines burned oil since 163k, starting to get codes for multiple cylinder misfire, cylinder 5 misfire, both cats, camshaft position sensor, sometimes it wont start unless I'm real nice to her. Time for a new engine? already replaced my tranny at 180k, and suspension/lift kit put on at 190k, thinking about going with a remanned engine with a warrenty. While everything is out i was thinking about throwing on some jba longtubes since rumor has it our stock ones crack bad. Whats a good price on a remann and install, or where could i find a quality used one? How much should i look at getting charged from a shop? I don't know much about engines so any help is appreciated. Thanks guys!
It is very possible the primary cats have broken down and drifted into the cylinder or cylinders causing permanent damage. Personally I would do a compression check on all cylinders before calling the engine quits. Sometimes smoke on start up is caused by bad pcv valves. Definitely worth a shot and you can rent a compression tester from just about any auto parts store. I would start there and then start looking for a new engine upon diagnosis.
Here is some #'s I found you should be looking at for a compression test
Compression pressure kPa (kg/cm2 , psi)/ rpm
-Standard 1,520 (15.5, 220) 200
-Minimum 1,324 (13.5, 192) 200
Differential limit between cylinders 98 (1.0, 14) 300
Reactions: nightowl
It is possible that you have a cracked head or blown head gasket, which can often result in coolant getting to your spark plugs, hence the misfires. I would start by pulling your plugs and inspecting them. If there is a white crusty looking buildup on them, then you can assume you have coolant leaking. And as presiously mentioned, do a compression check.
Reactions: nightowl
Vendor
Cats are notrious for failing usually around the 90-130k mile mark on most. The broken cat particles can be sucked back in the last 2 cylinders on each side causing ring failure. The manifold problem is so bad I have made a business out of it. Cajun Bpipes | shreveport, LA 71129
