Just kiddin man.....
I see you have an 08' Make sure you bring these directions with you when you find a dealership willing to do it.....
Tricky cause our Consult 3 did not have 08 options so i accessed through a
2007 350 z
After consult3 has connected to car :
1. Press Wrench sign upper Right side of screen.
2. Press ECM/Wrench sign just below Large Wrench sign
3. Press Engine / OK
4. Work Support
5. Engine timing at bottom of list
6. Fallow prompts to +2
!!!!!! make sure they actual hit the UP-DATE BUTTON !!!!!!
or it will not save..
Make sure engine is at normal operating temp. & also good to reset
Idle air volume relearn to @ 650 rpm with a/c off & steering wheel straight..
