1 - 3 of 3 Posts
So i want to put a spindle kit on my 4x2 Crew cab Nissan Titan. I was thinking of going with 2 1/2 inches in the front. Will i be able to clear a 33's with 17 inch wheels set up without rubbing. Does anyone have any experience?
Do you mean the 4" spindle lift or just the 2 1/2" spacer? I have the 4" spindle lift in front and I still rub with 33s. The pinch weld mod will fix that problem though.
stock wheels and a leveling kit you will be ok. you can do a nine inch wheel w/ no less than +18 offset and still barely clear. i have 325/60/18(about 1/2 inch bigger than 33) w/ nine inch wheels/ w/ +18 offset/ and dont rub. i cant get any closer though. there is like 3mm between my tire and wheel wells when i turn, but i do have a leveling kit
1 - 3 of 3 Posts
