I read somewhere on here earlier that you can fix this by inflating to 60 psi, turn on the truck and it'll kind of reset the sensor and then turn it off and deflate to 40psi or whatever the standard is.
Yeah - I take no responsibility for my above suggestion if the tire blows up and you get a piece of tread through your nose...Learjet said:I would not, repeat would NOT exceed the max sidewall pressure. You can damage your tire or have the tire blow out and cause injury.
Be careful !
