Tire Pressure
1546 10
I run 285/70/17 Terra Grapplers and keep them at 34-35 psi. Interesting to see what everyone keeps their tires at and what psi for different situations.
Thanks.
Merc
1 - 11 of 11 Posts
50 PSI everyday driving, i have load range E tires
Reactions: FlyFishMerc
38-40, with E-rated tires here too.
Do you think if I ran mine which are E rated at 38-40 that it would help gas mileage?
Thanks.
Merc
personally i think you should run air pressure wherever your tires wear the flattest it'll save you more money in tires than gas probably, just my 2cents
My truck gets driven in the dirt a lot so my tires are normally pretty low unless I have to drive to drive a long distance. Right now they are at 25 in the front and 20 in the rear. For highway driving I would put them at 35.
I run my stocks at 35 until the stupid dealer gets it, then they put them back down to 30.
I'm running 45psi in my E rated Toyos since that is about what I need to run to achieve the same load capacity/rating of the stock passenger tires.
Thanks.
Merc
Probably a very slight amount. I run mine at that spec because I've found it gives me fairly even wear.
Discussion Starter · #11 ·
I went to 38 yesterday on a trip back for Oklahoma. Ran great on Hwy but on city roads, the extra 3 lbs from 35 was way different. Much smoother on city roads and bumps with 35. A much better ride IMO.
Merc
1 - 11 of 11 Posts
