1 - 13 of 13 Posts
Hey Matt
I need some help determining what size tire would be perfect for my truck.
i am looking to do a 2.5 inch lift in the front at the most. i need a tire that wont look too goofy like small wise, i dont want it to affect the gas millage much if that's possible and have perfect bite for when i go offroading since i'm 2wd :)
thanks
Dave
Not sure exactly what size you need but i can write one off you don't. 275 / 70/ 18. It's what i have on mine and given a second choice, i'd have went with a 295.
those look pretty sick bro!
hows the gas millage on those?
should i just pull the trigger and get the 295's?
I researched alot on 1010tires.com to see what tires went with what rims and how big they were etc. The 295's would work on mine, but it's up to you and your needs
Supporting Vendor
Tire & Wheel Specialists
Hey Matt
thanks
Dave
Thank you for the post Dave. We would be happy to help you with your tire needs.
If you are looking to conserve as much fuel economy as possible, a narrower tire like the 275/70-18, might be the best option for you. Larger and wider tires are typically heavier (unsprung weight) and have more rolling resistance do to the contact patch on the road.
Are you running stock or after market wheels? If aftermarket, what are the wheel dimensions (width/offset)?
We look forward to your response and thank you for the opportunity at your business.
-Matt
yes i am running stock 18 inch rims.
275's are fine with me, what about 285's?
Hey it also depends on what brand as some makers don't make certain sizes. Shopping for tires / rims $ucks [email protected] Mine are Terra Grapplers and i love them, just wish they were bigger.
Discussion Starter · #8 ·
do the they wear over time?
Do they wear down fast?
Supporting Vendor
I would run the 275/70-18's. This size is a hair taller than the 285/65-18 size and is narrower in total section width which is good for rolling resistance.
If you want longevity out of your next set, I recommend looking into the Hankook DyanPro ATM RF10.
-Matt
Discussion Starter · #10 ·
will they look good with a mini lift?
Supporting Vendor
The 275/70R18 size is really the tallest size I would recommend for your truck based on what you are looking for. They are a little taller and wider than your stock tire.
If you want to go bigger than that you can look at the 295/70R18 size but to fit this size you will need to make some fender liner modifications to keep them from rubbing. This size will be a bit heavier than the 275/70R18 and it will push a bit more air down the road as well.
Discussion Starter · #12 ·
what brand tire would you recommend
Supporting Vendor
In the 275/70R18 size the Goodyear Wrangler Silent Armor Pro Grade would be my #1 recommendation for what you are looking for. These have a 50,000 mile warranty, they can take a beating and they won't wake the neighbors going down the road. If these are a bit costly for you my 2nd recommendation would be either the Hankook RF10 ATM or the Nitto Terra Grappler. Both of these tires go great on and off-road without breaking the bank.
Tires in the 275/70R18 size: Tire Products - Discount Tire Direct
1 - 13 of 13 Posts
