1 - 2 of 2 Posts
Hello all. Newbie here. I have a question about tire sizes. I have an 07 SE
2wd and I am in the process of ordering the CST 4" spindle lift with 2.5" spacers and a 3" block in the rear. I am going to be running my stock 18" wheels for awhile. I have searched this forum for answers and seem to find conflicting info. I would like to run Nitto Tera grappler in 325/65/18. Is there anyone out there that can tell me if this will infact clear? Does anybody have any pics of this setup? I do not mind doing the pinch weld modification to. Thanks in advance.
If your willing to do the pinch weld mod I'd think they will clear. A narrower and shorter 325/65/18 like the Kumho 78 AT might even clear w/o the pwm. You will definitely have more issues when you upgrade to a wider aftermarket rim, but especially the further away from the OEM 5.5" backspacing. For instance a 4.5" backspcing rim with even 33s and you might need the pinch weld mod.
Oh, I didn't even notice you're getting the spindles too. You might even clear the Nittos w/o the pwm.
Only issue with the Nittos might be that they are a bit wide for an 8" rim.
1 - 2 of 2 Posts
