tire size
1802 7
There was a thread with tire sizes and if they will fit without modding. I am getting the Mud Grappler and I have stock OR 285/70/17 now... But I want to get the Mud Grappler 35-12.5-17 which has a diameter of 34.84. The stock Rugged Trails are 33" diameter, so that is only 1.84/2 taller correct? So my tire is not even getting an inch taller and it seems that should be fine....But I am not the expert...Thanx all
Eric
P285/70R17 117T ORWL 61312 7.5 - 9.5 11.2 on 7.5 33 11 630 [email protected] * N/A N DT
1 - 8 of 8 Posts
You'll definitely rub without further mods (lift, or level with some trimming.) Those new tires are much wider than stock. OEM tires aren't exactly 33" in diameter either, slightly less.
yeah, I have 35's with a 6" lift, removed mud guards, pinch weld mod, and I still have some rubbing. Also these tires are noisy as hell.
I think you'll need a leveling kit at least. The side lugs on the grapplers are what rub, so 12.5" is not really the width of the entire tire.
Probably the biggest factor is what wheel you plan to run. Less backspacing (as most aftermarket wheels are) will increase the probability of rubbing.
BTW that 12.5" is section width, not tread width. You can usually find all the measurements off the Nitto website.
With 33"s, stock wheels, and level kit, I think you'll be good (probably even without cutting the pinch weld.) I was running a 33x12.5 on a 17x8 wheel with +12mm of offset (5" BS) and a PRG kit with no rub. Others on here have run BFG T/As in a near 35" size on factory rims with only a level kit.
1 - 8 of 8 Posts
