Hey guys -
I need new tires for my bone-stock '04 Titan KK with the 4x4 package. Truck is just a weekend driver and tow vehicle for our 25' travel trailer.
I am currently running 285/70R17. Replacements in this same size are running several hundred dollars more than similar 265/70R17.
Can I run the 265s as an economical replacement? If so, what should I be aware of?
Thanks.
Jim
265's are the OEM tire, so you shouldn't have any problem with them. The one thing I would look out for though, is usually a 265 tire is a P rated tire, not the greatest for towing with. I would look for an LT tire in that size if you can find one. It will have a stiffer sidewall, much better for towing
Thanks for the quick reply!
A local tire shop is offering a special on four Kelly Edge AT Light Truck 265/70r17s for $485 installed. This is almost half of what I've seen similar 285s going for, which is why I am intrigued.
Aside from a slight speed difference, any other considerations for going down to 265s? Also, any thoughts on these Kelly's?
Thanks.
Jim
My 06 CC had 285 70r17 oem tires. I've been running 265 70r17 winter tires for years. I don't tow anything heavy though. It will have a small affect on speedometer and odometer. I'd go for it at the price you're looking at.
Keep in mind you get what you pay for. Tires are not something you want to scrimp on, especially if you are pulling a trailer.
