1 - 1 of 1 Posts
4x4 Parts - Titan 4.56 Front Ring & Pinion Gears DTRP456FTTIT - Your #1 Source for Nissan Aftermarket Parts!
2004 and Newer Titan M205 Axle
SKU: DTRP456FTTIT
4.56 Ring & Pinion for M205 Front axle.
New gears allow for more torque, more accurate speedometer readings and proper engine rpm after installation of new tire size.
Made of 8620 hardened steel.
$309.95
Description
Installation Kit is sold separately
Installation Kit includes
Inner Pinion Bearing
Outer Pinion Bearing
Crush Sleeve
2-Carrier Bearings
It is important that you count the pinion flange splines.
Comes with 24 spline pinion
If you have a 29 spline pinion and need a 24 spline flange please select Appropriate Spline Count and Flange in the drop down menu above
1 - 1 of 1 Posts
