1 - 1 of 1 Posts
https://www.4x4parts.com/nissan/titan-5100-series-bilstein-rear-shock-p-7073.html
Titan 5100 Series Bilstein Rear Shock
SKU: SPBPTITRRHDWLIFT $78.00USD
2004-2014 Titan 2WD & 4WD with 2 inch Lift
Bilstein gas pressure shocks use monotube design which dissipates heat more effectively than a twin tube shock for cooler, more efficient operation and longer life.
14mm hard chromed piston rod.
The lightweight one piece rod guide is made from a unique aluminum alloy that maintains a nearly friction-free surface for longer life.
The superior seal design keeps dirt out of the working cylinder and prevents failure even under severe pressures of up to 2150 psi.
The piston head design allows independent tuning of the compression and rebound damping forces to provide optimum ride comfort and performance without compromise.
Patented digressive valving instantly reacts to changing surface conditions for maximum comfort and control on and off road.
Includes one shock, shock bushings and shock boot.
Shocks sold individually
1 - 1 of 1 Posts
