1 - 1 of 1 Posts
https://www.4x4parts.com/nissan/titan-arb-m226-differential-cover-p-7077.html
Titan ARB M226 Differential Cover
SKU: SPARBDIFFCOVTITAN $206.00USD
04 & Newer Titan With Rear M226 Differential
ARB's Differential Cover will protect your diff against the hazards of impact during competition or extreme off road use and are designed to counteract flexing of the axle assembly.
When off road, It is inevitable that obstacles will be encountered that could potentially inflict expensive damage on your differential. To prevent this, ARB's Differential Cover is available for a range of vehicle models and has been specifically engineered to protect the differential and ring & pinion set from any off road hazards.
High tensile nodular iron structure protects the differential and ring & pinion set from off road obstacles.
Computer optimized cross brace design increases the structural rigidity of the whole axle
Approach/Departure angle optimized by angled exterior surface
Prolonged carrier bearing life due to extra support to the bearing alignment
Additional housing strength helps keep the ring & pinion gears meshing on the flat faces of the teeth, Greatly increasing ring & pinion life and overall maximum load strength
Top quality, High power neodymium magnets are used in both the drain plug and the dipstick to collect metallic wear particles as the vehicle moves
Magnet location in the end of the dipstick allows the oil to be checked for tell-tale signs of internal damage or water contamination without the need to drain the oil
Low profile drain plug design resists damage from obstacles
Unique dipstick/filler cap design allows differential oil level to be adjusted for customized high driveline angles
Cover is powder coated, CNC machined, Then clear coated for a Durable, Professional, Long lasting finish. Hardware is case hardened & anti corrosive
Tensile cap screws (supplied) are recessed for protection against obstacles which might damage or loosen them
Pre-order now and be the first in line to receive your differential covers this coming November.
Comes In Red Or Black
Photo Of Red Cover Is Actual Part The Black Cover Is A Default Picture
1 - 1 of 1 Posts
