1 - 3 of 3 Posts
Anyone know if Armada rear end internal parts would be interchangable with the Titans? Read of a guy who used a pinion bearing, crush sleeve, spacer and pinion nut from an Armada on his Titan. Anybody know if this is true?
I realize the difference between the two rears as far as independant in the Armada and the Titans rear. Looking for the above parts.....pinion bearing, spacer, crush sleeve, and nut.
I know the pinion bearings are the same. P/N 381208S111. The spacer for the Armada is P/N 381667S000. I couldn't find the P/N for the Titan spacer. And the nut I would suspect should be the same.
Cool. i figured they should be the same. Thanks a lot for the help!
1 - 3 of 3 Posts
