So I had an issue with my 2012 Titan with the factory Rockford Fosgate system where it would not do anything except display the clock. I spent tons of time looking for a solution online to no avail. Disconnecting battery did not work, nor were the two radio fuses blown. (one under dash, one under hood) I could not find a lot of information on my year truck with the RF system, so I just started pulling fuses, and sure enough, under the dash the fuse for the amp was blown. I believe it was a 15. I changed it out and the radio powered right up and worked as it should. For anyone with the RF system having this problem, check that Amp fuse under your dash, it could be your easy fix as it was for me. In all of my searching online I never came across any mention of this fuse or this solution, and it is a very common problem. I hope this saves somebody a lot of headache and money!
Good Luck, all!
Where was this fuse located? I'm having the same issue, but don't want to take apart the wrong part of the dash. Was this where the radio is or above the gas and brake pedals? I need to find this and see if this is what my problem is.
On my truck it is underneath the glove box.
