Gonna need a new starter. I drove mine for over a year before it got to the point (20+ Key turns before starting) that I was convinced I would be stranded. Starter is buried under the intake manifold. Don’t attempt doing it yourself unless you are comfortable with wrenching.
I did mine today. It’s tight, but doable. They bolts holding the starter on are the biggest PITA. I eventually used a hammer to the ratchet to break them loose.
Good Luck. There are some solid write ups in the forums.
