Ok, I hadnt really seen this done. Just wanted to share a couple pics and give some notes of whats needed in case anyone else is considering doing this, as I went into it blindly and had to make it happen.
So these are the OEM Chrome 22" GM CK375 wheels. They are an option for the Sierras, Denalis, and Escalades. I am sure all of the other wheel types options will require the same work to make them bolt up. GM has 3-4 different 22" Chrome options, this one I just thought would look the best on a truck so I went for it.
Anyway. You will need new Lugnuts. I went for some Gorilla 13/16 Acorn Style Bulge in nuts (part #61128) which have approx a .910" seat. They are required, these wheels are designed for a M14 stud and we have a M12 stud. The wider 60* seat is absolutely a requirement.
Then I found out the fronts slightly rub the caliper pad support bracket, so some clearancing of said bracket was required (took about 20 mins per bracket plus labor of removing/installing them). I plan on getting blank chrome centercaps and affixing the Nissan emblem from my old caps to them.
Thanks,
Rob
Thanks,
Rob
