OK, so we've got this 2006 Titan now. Had it for almost 2 weeks and love driving it. But some questions...
1-this truck has the storage compartment behind the rear tire, driver's side. How do you open it? Inserting the key does not work, as the key will not turn.
2--I want to put a tri-fold bed cover on it, looking to keep the cost down so I don't want a hard shell one. Any suggestions on a good one? Looking to keep the cost under $300 if possible.
3--This truck has no lights for the center console. The radio screen and "passenger air bag" light both work normally, but the radio buttons and AC controls stay dark when I turn the lights on. I was told to check a 10 amp fuse under the hood, which was blown, and so I replaced it. It did not change anything, the lights still do not work. Going to go out to the truck in a minute and pull the new fuse to see if it's blown again....but they never worked, not even for a second.
4--the dimmer switch does not work at all. It does not dim or brighten the dash lights, and when you click it all the way up it does not turn on the interior lights. Is this a known issue, and if so, what kind of fix would take care of this?
I should mention that the truck is stock, but with a trailer brake installed--was that way when I got the truck. The trailer brake appears to be hard-wired in, I have not dug into tracing the wires just yet to see if it might be connected to these issues.
