1 - 20 of 47 Posts
The following is a list of common acronyms, abbreviations, or slang often used here at Titan Talk. These words are Titan, truck, or automotive related terms. To make an addition or correction to the list, simply reply or PM me.
Web site/Web Forum terms and acronyms are listed separately at the bottom.
(in alphabetical order)
2WD: Two Wheel Drive
4x2: Two Wheel Drive
4WD: Four Wheel Drive
4x4: Four Wheel Drive
ABS: Anti-lock Brake System
ABLS: Active Brake Limited Slip
AFR: Air/Fuel Ratio
AWD: All Wheel Drive (usually refers to a full-time transfer case)
BCM : Body Control Module
brake judder: Brake pedal pulsation, caused by warped rotors
BT: Big Tow package
CAI: Cold Air Intake
cap: capacitor, also can refer to a bed cover
cat: catalytic converter
cat-back: an exhaust system that replaces all factory parts from the catalytic converters back.
CC: Crew Cab
CEL: Check Engine Light
CST: California Super Trucks (suspension manufacturer)
CTD: Cummins Turbo Diesel
CV: Constant Velocity, as in CV Shaft or CV Joint
DCX: NY stock exchange symbol for DaimlerChrysler
diff: differential
DIN: the standard 2" size stereo head unit (1.5DIN is 3" and 2DIN or Double DIN is 4")
DMM: Digital Muliti-Meter
DOHC: Dual Overhead Cams
DR: Donahoe Racing (aka DRE, shock and coilover manufacturer)
dyno: dynamometer
e-locker: electronic locker, a differential that is locked electrically
ECM: Engine Control Module
EFI: Electronic Fuel Injection
FFV: Flexible Fuel Vehicle
FI: Forced Induction (super-charged or turbo-charged)
FWD: Front Wheel Drive
HID: High Intensity Discharge
HP: Horse Power
HU: Head Unit (car stereo)
HVAC: Heating, Ventilation, Air Conditioning
IFS: Independent Front Suspension
IRS: Independent Rear Suspension
KC: King Cab
LSD: Limited Slip Differential
LTPWS: Low Tire Pressure Warning System
MAF: Mass AirFlow sensor
mod: modification
MPG: Miles Per Gallon
MPH: Miles Per Hour
MY: Model Year
NA: Naturally Aspirated (non Forced Induction)
NAV: Navigation, usually refering to the factory NAV option.
OBD: On Board Diagnostic (aka OBD-II)
OE: Original Equiment
OEM: Original Equipment Manufacturer
OHC: Over-Head Cam
OR: Off-Road package
PC: Pro-Comp (suspension/wheels/tire manufacturer)
posi: posi-traction (limited slip differential)
pumpkin: differential
PRG: PreRunner Greg
PSI: Pounds per Square Inch
reso: resonator
RF: Rockford Fosgate
RWD: Rear Wheel Drive
SAS: Solid Axle Swap (replacing IFS with SFA)
SAW: Sway-A-Way (shock and coilover manufacturer)
SC: Supercharger
SES: Service Engine Soon
SFA: Solid Front Axle
SOHC: Single Overhead Cam
SRA: Solid Rear Axle
SRS: Supplemental Restraint System (air bags)
SS: Stainless Steel
SSV: Speed Sensitive Volume
TB: Throttle Body
TBI: Throttle Body Injection
TBS: Throttle Body Spacer
TC: Turbocharger
TC(A): Total Chaos (Arms)
TPI: Tuned Port Injection
TPM: Tire Pressure Monitoring system
TPS: Throttle Position Sensor
TQ: Torque
TSB: Technical Service Bulletin
TT: Twin Turbocharger; also can mean Travel Trailer
VDC: Vehicle Dynamic Control
VTEC: Variable Valve Timing and Lift Electronic Control (Honda proprietary)
VVT: Variable Valve Timing (generic)
WOT: Wide Open Throttle
Titan Talk Website Terminology
AFAIK: As Far As I Know
AFK: Away From Keyboard
BNIB: Brand New In Box
BTW: By The Way
Bump: Posting in a topic to show it as active.
FS: For Sale
FT: For Trade
FTW: For The Win
FWIW: For What It's Worth
FYI: For Your Information
GB: Group Buy
IIRC: If I Recall Correctly
IM: Instant Message (AIM, ICQ, etc.)
IMHO: In My Humble Opinion
JMO: Just My Opinion
LNIB: Like New In Box
LOL: Laugh(ing) Out Loud
Mod: Moderator
NIB: New In Box
NSFW: Not Safe For Work (probably don't want to look at it while at work)
NWS: Not Work Safe (see above)
OTD: Out The Door
PM: Private Message
PS: Photo-Shop
QFT: Quoted For Truth
ROFLMAO: Rolling On Floor Laughing My A$$ Off
STFU: Shut The F*ck Up
Troll: Someone who posts only to cause trouble; troublemaker
TTT: To The Top (bump)
WTB: Want To Buy
WTT: Want To Trade
Discussion Starter #9
baseballfanz said:
What about MAF? and mod can also be moderator
Thanks, added. Moderator was listed at the bottom under the website terms.
TBS - Throttle Body Spacer
What about "bump, bump" or "your bumped" when somebody reponds to a FS listing, Does that mean interested or done deal or what exactly?
Discussion Starter #14 (Edited)
They're bumping the thread to show that it's active on the New Posts and Active Topics lists. I'll add "bump" to the glossary.
BTW; no need to bump this topic, it's stickied.
PS: Several new terms added while I was here.
thx P's!
now that i got the dealer to install dem foglights, im gonna have to get em modified to run with my running lights. cant understand why w my Altima i had that option, but NOT with the Titan.
HU = Head Unit (I am guessing from reading posts). This is the dashboard center radio/Nav unit.
ATP = Automatic Transmission Park? This light comes on if you did not fully put the transmission in park and start the vehicle. It went out for me after I shifted into 4WD and back to 2WD.
1 - 20 of 47 Posts
