The other day the SES light came on. So I scanned it and came up with P0455, Which is evap control sys.( Emission control sys leak, Large. says scanner) So I did some research and turns out there is a TSB on the EVAP canister vent control valve. So I removed the unit and it was all dusty and dirty inside and wasn't sealing right. I cleaned it out and it started to seal properly. Reset the code and a week later it came on again same code. The kicker is another code came up with it p0128 thermostat function.(temp below reg. temp. says scanner) Followed the SM flow chart and looks like either thermo or temp. sensor. My dilemma is should I go to the stealership and have them throw a line of bullsh!t at me about my CAI or is the CAI a none issue. I do have the extended warranty, 50 dollar deductable though. If anyone has had this problem please chime in on your results any advice would help. And if anyone has the TSB #ntb06-095a with the part number of the new and improved evap canister vent control valve I would appreciate it. I can't find the TSB in full anywhere. Thanks
