1 - 18 of 18 Posts
Ever since i have bought my 05, about a year ago, from time to time it will turn over but not start. I wait for a minute or so and it fires up fine. This morning it did it a couple times, but then it fired and died. kinda like a single vrooom then nothing. The truck is from arizona and i'm in northern alberta were it's currently -27 celcius. The truck has no block heater but i stuck on a bold on oil pan heater, but the truck started fine all last winter and so far this year and it has been far colder then today. I just plugged the heater in and will try it again in a couple hours and hope if fires.
Any Idea's, battery fires strong but the motor wont run
thanks
Super Moderator
Your suppose to use the key to start it ...
Super Moderator
Well if I guess... it would be fuel system. Pump/filter is where I would start
Could be the fuel lines freezing.
Wow look how useful that Dodge became!! It's a road block! Probably doesn't run any better than an orange barrel but whatever.
IPDM=Intelligent Power Distribution Module. Yep, several have had a problem with it, due to so much integrated features in it. :)
Maybe it's not intelligent enough :tongue:
I have been having this problem, and it dont happen very often. Replaced the IPDM after reading that could be the problem. Week later it wouldnt fire again, after a few tries it finally fired and as i was idling out of the parking lot it died. i restarted and when on with my day and it hasnt done it since then, a few days ago. I wouldnt think it would have anything to do with the fuel system. Any ideas???
To the OP, i tried to use your name as my xbox live gamertag. They said no. Props!
Free bump to the top
1 - 18 of 18 Posts
