Hey folks,
Been having some issues with my 18 titan lately. It started one day I drove approx 15 miles to the grocery store, came out to my truck, and it started but idled very roughly then died. It then would not start. I had to be jumped off.
I drove straight to an autozone and they tested the battery and said it had a low charge but all cells were good and the battery checked out, but the charge was too low to test the alternator.
Since then I have driven the truck a bit, watching my voltage gauge and noticed that intermittently, when giving the truck throttle, the voltage drops. I would expect this to be different since this is when the alternator is supposed to be charging. One day when it was doing this, I stopped by a different autozone and they were able to test both the battery and the alternator, and said both checked out good.
I've driven the truck several times and no issues other than the intermittent voltage fluctuation that doesn't happen every time I drive it, until this week.
I've now had to jump the truck off 3 times this week. Once on Monday to leave the house, then when I got to where I was going, approx 25 miles, I had to jump it off again. Then I went to 3 more places and didn't need a jump each time, now this morning it's dead again and won't crank.
I have an appt with Nissan on Wednesday to diagnose, but they said since it's intermittent, if they can't replicate the issue while they have it, or find anything else wrong, they will charge me $150 for diagnostics to "pay their tech for their time". Shouldn't this be covered by the warranty? I feel I shouldn't have to pay anything with a full coverage warranty when there is a problem.
Any ideas? The truck only has around 57k on the clock, and I don't have much of anything pulling juice except for a dash cam that is on an ignition fuse, so it doesn't pull battery when off, and I do have a small amp for a sub but it also shuts off when the truck turns off, and the amp is very small, less than 400 watts.
LC
LC
