14.32 @ 94.07.........corrected time is a 14.12 no cool down, doing that now. I gained .1 with headers over stock gutted manifolds. Ill need a -300 or better da to run 13's, all in all im happy with it
nice time.14.32 @ 94.07.........corrected time is a 14.12 no cool down, doing that now. I gained .1 with headers over stock gutted manifolds. Ill need a -300 or better da to run 13's, all in all im happy with it![]()
The argument about an engine needing back pressure has already been answered so I'll skip that and dissect the remainder of your post.Backpressure is ABSOLUTELY necessary for an engine unless your valves are set up properly to run without it. It's not about how large the ports on the head are, it's about how well the head flows. Look at ANY honda head. the ports are tiny, but they flow stupid amounts of air through them due to the way its channeled through the head. Basically backpressure is needed to help maintain pressure in the combustion chamber. Unbolting your exhaust still wouldn't give you zero backpressure. You'd have to let it come straight out of the ports for that, and I promise you it will run like 10lbs of **** in a 5lb bag. Additionally, saying that "the intake, throttle body, intake manifold, heads and cams all dictate where the power will be made" isn't really accurate. You basically named all the parts of an engine, without the crank and pistons, which are the base of power production. They determine the displacement, strength, and compression ratio of the engine. Internal combustion effeciency and power production revolves around air. Exhaust will shift your power curve, and MIGHT get you as much as 15 ponies, but your real gains will come from finding ways for more air to get in, rather than out.
Nope not this time, timing was good and it maxed at 34 degrees. Afr's were 12.3-12.9 during the runs. My truck pulls hard as hell to about 80 mph and then the weight kills me I guess. It still pulls o.k but not like if it was 4600-4800#'s. I'm expecting too much out of my truck I think. To run a 14.09 corrected time is pretty damn good for a 5200# beast. LOL What kind of tires would be good to run on the track that have little resistance? Something I can run on the street too. If I get some I'll probably save my nitto's for just winter driving. I bet my tires are hurting my times by .1-.15 not because of the weight just drag all the way down.Was your truck pulling any timing this time out as opposed to last time?
Yea if you gut those cats you will gain an easy/free .1-.15 all day!! Once you get trutrac if they ever come out with it for 08 and up, you might be the first 13 second non header titan. Not many 07+ Titans race and they will be the ones to hit 13's w/out headers because you guys run on average .1 to .2 faster in the 1/4 mile mod for mod and I hit 14.18 before headers so you could easily hit 13.95 or better with traction.Wow only .1 this really makes me want to just muffler swap and gut my primary cats and get a retune. I would save $800.00, that's too much to spend on .1! Take that 800.00 and save it for when a true trac group buy goes on for 08+![]()
Yea thanks man!! I'm going to get some street radials hopefully, 07 IM, and a roll pan bumper. After the baby is born of courseGood job Jason, you'll get 13's soon bro, I think you'll get there with a little
more tweaking. 07 IM, DTT, 16inch rims and some MT ET Streets and 13's won't be a problem. Maybe you have found the limit of the 4wd efficiency, time to go 2wd with a LSD and sticky tires.
When was the last time you changed engine, trans, and diff oil?
Regardless those are good times and props for actually testing stuff out and giving back the results good or bad. Lots of guys your helping out in the process, definitly a good contribution to the board.
Congrats and god bless your family, hope all goes well with delivery and may the child be healthy. Are you ready for no sleep again for a little while ? lolYea thanks man!! I'm going to get some street radials hopefully, 07 IM, and a roll pan bumper. After the baby is born of courseWife is due in 2.5 weeks! oil is changed regular but I've never change tranny fluid. I'm on 51K right now, you think changing it would help? Diff front and rear were change at 40K.
Gotta be a little more specific on your setup bud, do you have stock manifolds and midpipes? Where where did you modify from, how far back is your mufflers and dumps, what size piping are you running before the mufflers? Etc. All that will affect what your lowend loss vs midrange and top end gain will be.Not trying to barge in here but I just switched to dual bullets this morning with no X-pipe. From what I understand on here there really isn't a loss other than towing torque if I leave it this way? Seems everyone on here running dual mufflers has some sort of merge or X-pipe.
Thanks
The x pipe helps create another scavenging point downstream from your headers. The further downstream your exhaust pulse travels the cooler it gets and the more it's velocity will slow down. The x pipe helps keep your velocity up. If your going to do full dualls it's best to keep the piping as short as possible but dumping it directly under the cab does make for an annoying ride for many. So then you have to choose between that, making an x pipe merge point, staying with long separate tubing that's velocity will be slowing down by the time you dump it behind your cab (especially after running through mufflers), or making some electronic cutouts upstream so when open you can have all the power potential you need for racing and still have a bearable exhaust for long rides when closed.
