Titan's V8 compression ratio?
13099 Views 12 Replies 9 Participants Last post by  Austin
Does anybody know?
I checked the Nissan website and did not find it listed in the specifications. The reason I ask is I'm interested in the performance mods Infiniti has made to the 5.6 Endurance engine.
The QX 56 (Armada having survived Infiniti finishing school) is rated at 315 hp., an additional 10, with 390 lb.-ft. an additional 11. The Infiniti website lists the compression ratio at 9.8:1, and it requires premium fuel.
I suspect the performance increase is nothing more than revised mapping of the electronic control unit and maybe a refined exhaust and intake. However, if the compression ratio has been increased Infiniti has done some additional work tot he engine.
Thoughts?
1 - 13 of 13 Posts
Compression
Quad T said:
Does anybody know?
Thoughts?
The Titan's engine compression is also 9.8:1. I think the difference was mentioned on another thread as being titanium lifters and some other mods.
That is about all I know, others have more indepth info if you need it.
the titanium valvetrain and high compression is on the 4.5L engine...not the 5.6L in the titan or QX56. I would suspect the HP diff is a matter of intake or exhaust being more efficient or possibly ECU "tuning."
Or maybe the HP diff is a function of the person operating the word processor.
· Banned
General Endurance 5.6L Info
Cylinder arrangement: V-8
Displacement: cm3 (cu in) 5,552 (338.80)
Bore and stroke: mm (in) 98 x 92 (3.86 x 3.62)
Valve arrangement: DOHC
Firing order: 1-8-7-3-6-5-4-2
Number of piston rings: Compression-2 Oil-1
Number of main bearings: 5
Compression ratio: 9.8
Compression pressure kPa (kg/cm2 , psi)/ rpm
-Standard 1,520 (15.5, 220) 200
-Minimum 1,324 (13.5, 192) 200
Differential limit between cylinders 98 (1.0, 14) 300
Exhaust valve open duration: 232 degrees
Intake valve open duration: 230 degrees
Intake valve open/Exhaust valve open overlap: 5 degrees
NGK Spark plugs Double Platinum tipped –
Standard Heat range: PLFR5A-11
Hot type: PLFR4A-11
Cold type: PLFR6A-11
Gap (nominal) 1.1 mm (0.043 in)
i doubt they had to drop compression .2 just to run on reg gas. there are many engines with 10:1 or even higher that are designed to use reg.
1 - 13 of 13 Posts
