1 - 9 of 9 Posts
Benefits of not lifting: Better MPG, better ride quality, easier to get in/out of truck, cheaper, can fit in garages
Benefits of lifting: Bigger tires, truck is higher off the ground to drive over stuff (yes I know you're still limited by the diffs), you get the truck sitting how you want it.
At the end of the day who gives a s*** what other people say to do to your truck? It's your truck, not theirs. Do what makes you happy.
If you don't want to drop a ton of cash on a lift you can go just a little higher with Bilsteins on middle perch (1" lift), leveling spacer on top, 1-2" blocks in the back depending on how much rake you want. I will have that tomorrow so I can show you before/after if you want.
I'm in the middle of my prg procomp lift. So far so good. Just waiting on the coilovers to get here then button her up
You can fit 34s easy with a 2.5" lift. With a 6" you'll probably run 35s. Not a big difference real clearance. More the wheel well gap and aesthetic look. Whatever your preference is.
Ya! I'd love to see a before and after! That would be amazing! Thank you!
Here you go. Sorry it took so long. Went up exactly 1" from before. Front and back wheel well heights are equal.
1 - 9 of 9 Posts
