Any used this? Can you report how accurate realtime HP readings are?
I entered all the needed info correct, including truck weight and my weight and gas weight.
I Stomped it at 50, I went sideways but stayed in it , it reported back I was way over 500 hp?????
So MEH
PS I bought in 09 as second owner, seemed like last guy added the big stereo an alarm, but nissan had no data. At idle it goes mmmm lup mmmm lup mmm lup.. Im wondering if he put cams in before i bought it lol, What a lottery win that would be!!!
I have it, and a 12$ amazon bluetooth box...
It's a neat toy... I dunno how accurate... but makes sense it should be for hp, work over time=hp it's simple math. That said.. is the GPS data accurate, does the code run with an accurate timing method, other software on the phone slowing calculations... etc...
Do you know the real rolling weight of your truck? (like... it should probably run over a scale to be 100%)
Is the phone mount solid? Did you calibrate the accelerometer first then leave the phone oriented the same as when calibrated?
A few degrees change in the angle of your phone would cause way incorrect readings (i.e. if you calibrate it vertical, then lay it on its back, you would add a whole G to one axis, that's a lot...)
I'm interested in the rolling weight if you do scale it...
I have torque pro, not sure how accurate the HP is. My rolling weight with me and the topper is about 6200 pounds, topper is about 200, I'm a bit over that at 215
Reactions: BWV
I not sure what to say as far as if thats accurate. I've had it for a few years and its a great program even if it did nothing more than read/clear codes. Ive also used it to get Injector balance rates for a duramax. I also like all the other diag features it has.
I gotta say, for the 17$ I have invested I'm pretty happy with it.
