Yes, the torque specs are 15 ft-lb, here is the diagram directly from the Titan A60 Field Service Manual. I modified/added a couple of the images to help a little.
This is the thermostat housing. Make sure the rubber O-ring covers slides over the thermostat itself. The gasket has a slit around the entire inner diameter to ensure proper fitment. Also, make note of the orientation of the ''Jiggle valve" when re-installing thermostat. The jiggle valve allows trapped air to exit, since the trapped air will rise to surface, so to speak.
Just little tid bits I thought i'd share. Hope this helps you further.
Just thought I'd add this. Couldn't see corys pic. Was searching for fan clutch and clutch to pulley specs
Sent by my thumbs using whatever means necessary
