When a vehicle has a tow rating of 9500lbs is that with the truck box empty? or is that with a load?
Yup that helps alot. I was just not sure how you could get the 9500 tow rating. The only thing i will be towing is a pair of jet ski's! :futwice:CaliforniaTitan said:The 9500 number is an actual tow number but keep in mind this is with the full Class IV setup. It is also recommended to not exceed 80% of that number for safety.
The bed wieght can be up to the 1500 (Cant remember the actual number off the top of my head) and still tow that.
IF your thinking 5th wheel though, you have to take that toungue wieght off of your bed capacity and off the 9500 number.
Hope thats clear as mud...LOL
Chris
No, when towing, you have to deduct the tongue weight of the trailer from the payload before you can determine how much you can load in the rest of the truck (bed payload, passengers etc.)The bed wieght can be up to the 1500 (Cant remember the actual number off the top of my head) and still tow that.
5800lbs with no brake controler?? I bet a 2500chevy would struggle stopping that too with no trailer brakes.heres an idea, dont tow big loads with a half ton pickup, even the big bad titan is still not an hd, i towed a 30ft trailer around town and ont the highway. that trailer pulled my titan all over and the place. it wieghed around 4800 dry and it had 10 2x12s 10 ft lomg, [probably another 1000lbs], well below the 9500lbs limit[yes it has the max utility packacge] brakes could barely stop it. just cause a spring deosnt brake doesnt mean its ok. the engines up to towing 8, 9k no problem, but the 3.37:1 ratio, brakes and suspention arent.dont take my word for it, tow ur big trailer w ur titan, and then w ur buddys chevy 2500 thats where the titans weakspot shows up, cause empty itll beat most chevys w the 6.o liter. not a real towing monster though
You didn't say what type of trailer it was, but if it's a utility trailer, did you have enough weight on the tongue?heres an idea, dont tow big loads with a half ton pickup, even the big bad titan is still not an hd, i towed a 30ft trailer around town and ont the highway. that trailer pulled my titan all over and the place. it wieghed around 4800 dry and it had 10 2x12s 10 ft lomg, [probably another 1000lbs], well below the 9500lbs limit[yes it has the max utility packacge] brakes could barely stop it. just cause a spring deosnt brake doesnt mean its ok. the engines up to towing 8, 9k no problem, but the 3.37:1 ratio, brakes and suspention arent.dont take my word for it, tow ur big trailer w ur titan, and then w ur buddys chevy 2500 thats where the titans weakspot shows up, cause empty itll beat most chevys w the 6.o liter. not a real towing monster though
