1 - 3 of 3 Posts
Hello all,
Just got my 17 Titan XD PRO4X about a week ago. It has about 20k miles on it and enjoying it so far. I know I will be swapping out these tires because I hate these grabbers. As far as I know its still stock height...I measure the wheel wells last night and there is only a 1" difference between front and back does this sound correct for stock? Also since its only 1" difference I probably wont be leveling it. My question is in its current form anyone run 33x11.5x18 wheels on stock rims without level or lift?
The size you're describing is basically 275/70r18, and I think that's an OEM size on the 2017 Titan. Should fit, but you could always measure what you have, and then measure your clearance. Pretty easy math to figure out how much of your clearance you're going to use up with a bigger tire.
Supporting Vendor
Tire & Wheel Specialists
Welcome to the site and congrats on the XD, @TitanJake !
I'm not sure on the ride height portion of your post, hopefully someone will chime in on that, but as dubyam noted, the tire dimensions you outlined will fit your application.
There are no manufacturers (that I am aware of) that produced a high flotation size of 33x11.50R-18, however, metric sizes such as 275/70R-18 is common as is 285/65R-18 and 285/70R-18.
You can use this TIRE SIZE CALCULATOR to see the mathematical dimensions for the metric sizes.
1 - 3 of 3 Posts
