Does anybody really know how this system works??? I had Firestone reset after fixing a leak. It was fine until one morning my tire pressure dropped below the threshold indicating low pressure. Silly me, I kept driving. Finally when I finally filled up the tire it was below 25 PSI. Now the TPMS indicator "Blinks" for the 1 to 2 minutes at ignition then stays on even though the tire pressures are OK! - My understanding is that when it drops below an "OH SH*T!" level it needs to be reset by the dealer or someone with the knowledge and equipment to do the work Charging in excess of $30 to $50 dollars!!!
Can someone confirm or add to this info. Thanks. - makes me want to purchase the necessary equipment and start low balling all the service departments out there!
- 2007 LE Crew w/o Nav 122,000 miles - left rear axle seal leaking after an additional 60K miles.
