Hi I'm a noobie here. I'm 16 and i just got my first truck (the Titan) I've noticed that even with turning the VDC off, I still have some troubles power sliding (drifting) and doing donuts and such things off road. It seems that once the wheels start spinning and the RPM's get up high enough, the governor kicks and begins to let off the gas. Anybody else have this problem? If so, is there something you can do about it? Thanks.
the VDC is a fail safe system that keeps young driver like yourself under control
I'll bet it's not the VDC. Check your slip light.
Kinda hard to drift with that one wheel peel going on ain't it?? Do you have a TruTrac? Welcome by the way..........
Does VDC actually do? When should I use it?
