I have a 2017 Titan RWD that I use to haul a small lite travel trailer. The tongue weight is low but I seem to have excessive bounce . Anyone else have this issue?
You using a WD hitch?
That will help a lot.
Reactions: Rudyt50
trailer bounce is usually not enough tongue weight. It is acting like a see-saw with your trailer with the axle of the trailer as the pivot point. You feel the trailer tongue lifting the back of the truck, causing the bounce. You need to add more weight in front of the axle of the trailer to keep it down, so it is heavier then the back end of the trailer or get a WD hitch
