Trailer running lights - which fuse?
42416 10
I searched to find about 800 threads on trailer lights but could not find which fuse it is. My fuse panel (behind battery) has several marked tow or trailer tow and they are all good. AMF I pulled every fuse that even came close and still nothing. The brake lights and turn signals work.
1 - 11 of 11 Posts
bump for info
If you can't find the fuse in the boxes under the hood or in the panel on the passenger side dash, maybe you had the BCM recall work done where they replaced the BCM harness. The replacement harness (under the driver side dash) has fuses.
so just check all them fuses under the dash?
Try fuse #32 in the box behind the battery.
nvm i found the problem it is the f4 fuse
Old thread, if anyone is still following it. Where is the F4 fuse? I have the same issue? I have a feeling this junk trailer I picked up might have shorted the tail lights to the frame and killed it before I could fix it.
On my 2013 Titan, F4 is way down towards the bottom of the IPDM.
My challenge is how do I access, pull and replace this fuse? I have a pair of 7" needle nose pliers that can't get there due to the angle and lack of grip.
Is there a special Nissan tool for this fuse?
Thanks,
1 - 11 of 11 Posts
