I have a new 2017 Titan Pro-4X. I love the truck but had a real white knuckle experience this weekend and need some help.
The tuck bed was loaded with camping gear (Maybe 500 lbs) and I was towing a 14 foot tandem axle flat bed trailer. The trailer probably weights a 1,000 pounds empty and a had a four seater rzr on it (2,000 lbs). In total, I should have been around 3,000 lbs.
On the way out of town, I felt a little sway, but nothing crazy. I thought maybe it was just the wind. One the way home, I almost lost the whole thing. The trailer started fishtailing uncontrollably. I was able to slow down and save it, but I was very close to losing control.
To make it home, shifted the load forward adding more tongue weight and air up the tires on trailer to max. It still did not feel real solid.
I have pulled this trailer probably 20 times loaded the exact same way with a Silverado 1500 and never felt any sway.
Any recommendations?
Is it the truck? Taller suspension on Pro-4x? Taller P series tires?
Is it the trailer? Should I add sway control device? Trailer does not have brakes and I think brakes would have helped with the recovery.
Thanks in advance.
Phillip
Thanks in advance.
Phillip
