Many thanks to MartyG007 for posting a wiring diagram for the trailer tow wiring circuits in a related post. It has been very useful in understanding the how and why of the trailer circuits.
I had a short in my trailer that has blown a fuse/relay in my Titan (06). The output pin for running lights or tail markers on the 7 pin is dead. I have checked ALL fuses under the hood, (just now discovered there may be a couple more under the dash, will get to them soon), but I suspect that Trailer Tow Relay #1 is the problem based on symptoms and the wiring diagram. I would like to pull it and check it but I am having difficulty getting it out of the fuse block. Do these relays have a lock of some kind that needs depressed in order to remove them? I have pulled as hard as I dare and I am hesitant to pull too hard, or try to pry them out without some advice. Perhaps there is a tool that is helpful? Any ideas will be greatly appreciated
