1 - 2 of 2 Posts
Can someone tell me where the actual location of the trans cooler is? Not the goofy bottom of the radiator thing but where the cooler is. Where does the line go after it leaves the radiator?
The radiator cooler is located forward of the radiator and just behind the grill. Facing the front of the truck with the hood open, on passenger side, look between the coolant tank and the radiator and you will see both metal and rubber tubing that goes to the transmission cooler. You may need to peel back some of the foam to see where the tubing goes to the cooler.
1 - 2 of 2 Posts
