come on guys...am i the only one with this issue????
any ideas???
any ideas???
Sounds like a valve is getting stuck or one of the relays in the TCM is going bad.im running the regular power tune, not the performance power tune with 91 octane.
when it gets up to where it should shift...its just wont, it'll run at the same RPM and just stick there. if i wait for a good 5+ seconds, it'll eventually shift.
i don't like to wait because to me, it doesn't seem right so i will either let off the gas, then give it gas and then it'll shift or what i normally do is move the gear shift over to 4, then back to D and it shifts instantly.
ETA: its been doing this before i put the BD tune on it.
Maybe a gear shop ... What diameter tires are you running, and do you have the 2.94 gears or the 3.36 gears?i just took the truck in for the IPDM recall last month but im guessing thats different than the TCM relays...
stupid question but which would be better to go to....Dealer or Transmission shop??
Mine didn't have any issue with my 33.5" M/T's but with 33.98" Terra's it does the same thing. In my case it's the gearing change from the larger tires affecting the torque converter locking it into overdrive. I would think it would happen with even smaller than 34's if you have the 2.94 gears.
Wonder what it would be for most 2.94's, I know that not all of the 3.36's have issues with 34's, but on mine it was noticeable as soon as they went on, and they are 11 pounds lighter than the 33.5" tires which never had the issue.Little tow gear and had 275-70-18's, 33.2" tall, on my Titan and never had shifting issues.
i saw that thread and i hope to do it next weekend when i get some extra time.Wouldn't be a problem with your 3.36 and a 33.2" tire. Maybe one of the other suggestions.
Have you changed your fluid? I did the drain and fill on mine, (5 times a few months apart, this gives close to 90% new fluid), and it is way easier than even doing engine oil/filter changes. http://www.titantalk.com/forums/tit...2468-transmission-drain-fill.html#post2156564
