Hello,
I have noticed, and this is new since the truck did not use to do this, that my the tranny temp in my truck (06 Titan SE) goes through the roof when towing, specially going up hill. Someone here mentioned a while back the fan clutch, however, I don't know how to test it.
Does anyone have any information on how to test a faulty fan clutch and anything else to check for regarding hot tranny when towing?
I have been driving this truck for 76K miles and I have towed several trailers before (4th gear, downshift when too hot, clean tranny fluid...) All of this helps, however, the tranny temp goes up sooner, more often and more dramatically than it used to.
Any ideas would be appreciated?
Mike
When was the transmission fluid last changed, as in a full 11 quart change, not the 3 or 4 quart change when you only open the drain plug.
I would love to see this answered as this was an issue with my 06 and its been bugging me ever since. It also started happening to me at around 76,000 miles.
I also have an 06 that has the same issue. I towed up a large grade that I always tow up and I have never had an issue with the transmission running warm. However, the last time I went up it, the transmission gauge went up to the maximum "still within operating range" mark (BDGT said 213 degrees). I've recently put a PML tranny pan on, so we'll see how that goes next time I tow. Oh, and the tranny fluid has been changed every 30K miles, with a fluid exchange using the cooler lines at 90K.
