1 - 3 of 3 Posts
?Does anybody know if you can take the transfer case off a 2007 4X4 transmission and put on a 4X2? I have found some replacement 4X2 trans but not sure if the tail shaft is the same on the 4x4 and 4X2 like some other vehicles are. And if I do this is there any other things that is different like gear ratio ETC ?
And how do you reset the ECM/TCM is as easy as using a OBD2 scanner and erase the memory.
Thanks for reading any help is appreciated
The transfer case would bolt onto the 2wd trans, BUT only after removing the 2wd rear tail housing, and of course replacing the trans out put shaft with a 4wd unit...So the answer is yes it will work, but no it doesn't just bolt on...
1 - 3 of 3 Posts
