Can anyone tell me how to check my transmission fluid. I think its leaking from the cooler. Otherwise my radiator is leaking oil,( thatsa a joke I know radiators do not use oil). And my transmission seems to slip just a bit and it get worse the more time goes on.
Reactions: FAlpha
Chances are, you're making a strawberry milkshake. When cool, pop the radiator cap and take a look. Lots of guys bypass the stock/built in transmission cooler for this reason. Yes, stop driving it is an understatement. You need a new radiator and a transmission fluid replacement, Matic S is what you're looking for and a CSF radiator if you're on the cheap.
Sent from my SM-G900V using Tapatalk
If you have the afore-mentioned problem, then it's already too late.
