Discussion Starter · #2 ·
Im having a leak where the transmission meets the yoke sleeve.. the leak is coming from where the two come together but from the outside. I see other posts but it's difficult to determine my specific issue.. here are some pictures of leak.. I believe it's the seal... cause it's on outside of sleeve not from inside... can someone help me determine issue and what part/part number I need to get start the process of fixing it? If I'm wrong please correct me.. these pics show a lot of the tran fluid that way going everywhere
I think the leak is further forward and is blowing back.
I would clean it off and then search for the leak.
I did last night. Will have update, because as of this morning, since I cleaned it, it will no longer shift out of park.. the shift knob will move but it doesn't even seem to be connected.. so i have to dive back in it after work. Will update... but here are some of the pictures after the clean...
Discussion Starter · #5 · (Edited)
Ok got the transmission shifting.. the cable detached.. Here is a pick of leak.. sorry i am not versed in the transmission verbage but it's leaking right where the red meets the silverish.. coming between the two... I'm assuming yoke sleeve seal.. that's what I've been reading online. This is 08 titan.. anyone have any solution.. I have access to military base shop... so all lifts and tools at dispense...
You need to replace that seal.
