Hi,
I'm getting a strange behavior from my truck's transmission, but I've only owned it a few weeks so don't really have a frame of reference for what is normal.
Living in a hilly area and coming from a manual transmission, I've been manually putting the Titan into 4th, 3rd, etc. when coasting down steep hills to maintain speed without having to brake.
However, if the RPM's are below ~2500, the transmission does a weird pulsing thing where the engine speed raises and lowers by ~300RPM over and over. It feels like someone is sitting there lightly tapping the gas pedal on and off, but my feet aren't touching anything. Obviously the transmission will disengage a manual gear if the RPMs get too low, but it seems like the 1500-2500 range should be fine for coasting downhill.
This happens in manually selected gears 1-4 but hasn't happened when in D. Transmission seems to shift fine and function normally otherwise, which makes me think this is some sort of software/programming issue. If I shift or tap the gas/brakes, the problem generally goes away for a brief time.
Has anyone experienced this before? Any tricks to try? I searched but couldn't find anything.
