Funny thing is I have never had any engine or transmission problems with my 2007 Titan SE. I drove home the other day from an appointment and pulled into my driveway as normal and shut it off. When I came out a while later to drive to my remodeling job and started the engine, I had no gears in forward or reverse. The trans fluid is clear red and has no off smell. I topped off the fluid which was a little low and tried to run it a couple of more times later in the day. The shift lever feels disconnected, as there is no physical sign that it is moving thru the gears. Just nothing. I have 135,000 on it and never had a bit of trouble with the tranny. Any Ideas??? The driveshaft has been replaced and I have run with that for several months. It doesn't turn when I put it in gear so that should eliminate a problem with the rear end. Thoughts???
