Transmission temperature gauge
1319 1
'05 Titan SE without towing package. Can a transmission temperature gauge be added, either the one that came with the towing package or an aftermarket?
What was different on the trucks with the towing package vs. without?
1 - 2 of 2 Posts
I added a trans temp gauge so it can definitely be done. You would need a gauge pillar pod to mount it though, I have engine temp, trans temp, and rear diff temp. I'm not sure of all the differences between bigtow and non bigtow models. The only things I think are gear ratio's and an external trans cooler. I would think maybe a stiffer rear suspension also, but I'm not positive on that one
1 - 2 of 2 Posts
