The rubber trim located at the bottom of my front window is pealing off from the center out. Has anyone experience this, if so how do you fix it?
When I push the trim back into place it just pops out again. ImageUploadedByAG Free1379690762.676301.jpg
Remove your cowl (paint it with plasti-dip or bedliner while you have it off) then slip the trim back on before you reinstall it. You may not be able to just push it back down with it the way it is.
