Trouble code p1757
16928 3
Today my titan threw the code p1757 and was struggling to get off to a start form a dead stop. My mechanic said he thinks it might be the front bake solenoid....any ideas? Is this inexpensive? I mean relative to a new tranny anything is inexpensive Help please!!
Thanks
DTC P1757 FRONT BRAKE SOLENOID VALVE PFP:31940
Description ECS00B01
Front brake solenoid valve is controlled by the TCM in response to signals sent from the PNP switch, vehicle
speed sensor and accelerator pedal position sensor (throttle position sensor). Gears will then be shifted to the
optimum position.
CONSULT-II Reference Value ECS00B02
On Board Diagnosis Logic ECS00B03
 This is an OBD-II self-diagnostic item.
 Diagnostic trouble code “P1757 FR/B SOLENOID/CIRC” with CONSULT-II is detected under the following
conditions.
– When TCM detects an improper voltage drop when it tries to operate the solenoid valve.
– When TCM detects as irregular by comparing target value with monitor value.
Possible Cause ECS00B04
 Harness or connectors
(The solenoid circuit is open or shorted.)
DTC Confirmation Procedure ECS00B05
CAUTION:
Always drive vehicle at a safe speed.
NOTE:
If “DTC Confirmation Procedure” has been previously performed, always turn ignition switch “OFF”
and wait at least 10 seconds before performing the next test.
After the repair, perform the following procedure to confirm the malfunction is eliminated.
WITH CONSULT-II
1. Turn ignition switch “ON”. (Do not start engine.)
2. Select “DATA MONITOR” mode for “A/T” with CONSULT-II.
3. Start engine.
4. Drive vehicle and maintain the following conditions for at least 5
consecutive seconds.
ACCELE POS: 1.5/8 - 2.0/8
Selector lever: “D” position
Gear position: 3rd  4th Gear (FR/B ON/OFF)
Driving location: Driving the vehicle uphill (increased
engine load) will help maintain the driving conditions
required for this test.
5. If DTC is detected go to AT-142, "Diagnostic Procedure" .
WITH GST
Follow the procedure “With CONSULT-II”.
Item name Condition Display value (Approx.) (A)
FR/B SOLENOID
Front brake engaged. Refer to AT-20 , AT-22 . 0.6 - 0.8
Front brake disengaged. Refer to AT-20 , AT-22 . 0 - 0.05
BCIA0031E
AT-142
Revision: August 2006 2007 Titan
Diagnostic Procedure ECS00CCD
1. CHECK INPUT SIGNAL
With CONSULT-II
1. Turn ignition switch ON.
2. Select “MAIN SIGNALS” in “DATA MONITOR” mode for “A/T”
with CONSULT-II.
3. Start engine.
4. Read out the value of “FR/B SOLENOID” while driving.
OK or NG
OK >> GO TO 4.
NG >> GO TO 2.
2. CHECK TCM POWER SUPPLY AND GROUND CIRCUIT
Check TCM power supply and ground circuit. Refer to AT-169, "MAIN POWER SUPPLY AND GROUND CIRCUIT"
OK or NG
OK >> GO TO 3.
NG >> Repair or replace damaged parts.
3. DETECT MALFUNCTIONING ITEM
Check the following items:
 The A/T assembly harness connector pin terminals for damage or loose connection with harness connector.
OK or NG
OK >> Replace the control valve with TCM. Refer to AT-247, "Control Valve With TCM and A/T Fluid
Temperature Sensor 2" .
4. CHECK DTC
Perform “DTC Confirmation Procedure”.
 Refer to AT-141, "DTC Confirmation Procedure" .
OK or NG
OK >> INSPECTION END
NG >> GO TO 2.
@ DentonTitanOwner what did you end up doing..cause im getting these codes also:bangit:
