Actually might be a bad passenger side rear O2 sensor... Circuit codes either are bad connectivity or bad sensor tip (not properly heating/reading)... Try disconnecting the harness connectors, blow out with air, reconnect and make sure they snap together and are snug... Reset ECU, than drive it for a bit to see if SES codes trip again... If the same codes trip, replace the O2 sensor... That's my speculation...
